325
A checkbox event occurs when a field group is dynamically added to the field layout.
<Grid Grid.Row="2">
    <igDP:XamDataGrid x:Name="U_DataList"
                      BorderBrush="{StaticResource BorderColorBrush}"
                      IsGroupByAreaExpanded="False"
                      SelectedItemsChanged="U_SampleData_SelectedItemsChanged"
                      Style="{DynamicResource XamGridStyle}">
        <igDP:XamDataGrid.Resources>
            <Style TargetType="{x:Type igDP:DataRecordCellArea}">
                <Setter Property="Background" Value="{StaticResource BackColorWhiteBrush}" />
                <Setter Property="BackgroundAlternate" Value="{StaticResource BackColorDarkWhiteBrush}" />
            </Style>
            <Style TargetType="{x:Type igDP:CellValuePresenter}">
                <Style.Triggers>
                    <DataTrigger Binding="{Binding Path=DataItem.IsChecked, Mode=TwoWay}" Value="True">
                        <Setter Property="Background" Value="{StaticResource LightBlueBrush}" />
                        <Setter Property="BorderBrush" Value="{StaticResource LightBlueBrush}" />
                        <Setter Property="BorderThickness" Value="0.3" />
                    </DataTrigger>
                </Style.Triggers>
            </Style>
            <Style BasedOn="{x:Null}" TargetType="{x:Type igDP:RecordSelector}">
                <Setter Property="Margin" Value="7,2,0,0" />
                <Setter Property="Template">
                    <Setter.Value>
                        <ControlTemplate TargetType="{x:Type igDP:RecordSelector}">
                            <CheckBox HorizontalAlignment="Center"
                                      VerticalAlignment="Center"
                                      IsChecked="{Binding Path=DataItem.IsChecked, Mode=TwoWay}" />
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
            </Style>
            <Style BasedOn="{x:Null}" TargetType="{x:Type igDP:HeaderPrefixArea}">
                <Setter Property="Visibility" Value="Visible" />
                    <Setter.Value>
                        <ControlTemplate TargetType="{x:Type igDP:HeaderPrefixArea}">
                                      Checked="CheckBox_Checked"
                                      IsChecked="True"
                                      Unchecked="CheckBox_Checked" />
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
            </Style>
        </igDP:XamDataGrid.Resources>
        <igDP:XamDataGrid.FieldSettings>
            <igDP:FieldSettings AllowEdit="False" />
        </igDP:XamDataGrid.FieldSettings>
        <igDP:XamDataGrid.FieldLayoutSettings>
            <igDP:FieldLayoutSettings AllowClipboardOperations="All"
                                      AutoFitMode="ExtendLastField"
                                      AutoGenerateFields="False"
                                      CopyFieldLabelsToClipboard="True"
                                      HighlightAlternateRecords="True" />
        </igDP:XamDataGrid.FieldLayoutSettings>
        <igDP:XamDataGrid.FieldLayouts>
            <igDP:FieldLayout x:Name="U_FieldLayout" >
                <!--#region Checkbox-->
                <igDP:Field Name="IsChecked"
                            Width="50"
                            HorizontalContentAlignment="Center"
                            VerticalContentAlignment="Center"
                            Visibility="Collapsed" />
                <!--#endregion-->
                <!--#region Color-->
                <igDP:TemplateField Name="Color"
                                    Width="60"
                                    Label="Color"
                                    LabelTextAlignment="center">
                    <igDP:TemplateField.Settings>
                        <igDP:FieldSettings CellClickAction="SelectRecord" />
                    </igDP:TemplateField.Settings>
                    <igDP:TemplateField.DisplayTemplate>
                        <DataTemplate>
                            <Rectangle Width="40"
                                       Height="2"
                                       Fill="{Binding Path=(igEditors:TemplateEditor.Editor).Value, RelativeSource={RelativeSource Self}, Converter={StaticResource ColorToBrush}}" />
                        </DataTemplate>
                    </igDP:TemplateField.DisplayTemplate>
                </igDP:TemplateField>
                <!--#endregion-->
                <!--#region Name-->
                <igDP:Field Name="Name"
                            Width="1*"
                            HorizontalContentAlignment="left"
                            Label="Name"
                    <igDP:Field.Settings>
                    </igDP:Field.Settings>
                </igDP:Field>
                <!--#endregion-->
                <!--#region AcquiredTime-->
                <igDP:Field Name="AcquiredTime"
                            Width="1*"
                            Format="yyyyMMdd HH:mm:ss"
                            Label="Acquired time"
                </igDP:Field>
                <!--#endregion-->
            </igDP:FieldLayout>
        </igDP:XamDataGrid.FieldLayouts>
    </igDP:XamDataGrid>
</Grid>
public void AddProductField(string model_name, string product_name, string unit)
    FieldGroup group          = new FieldGroup();
    group.Label               = model_name;
    group.LabelTextAlignment  = System.Windows.TextAlignment.Center;
    group.LabelPresenterStyle = Application.Current.FindResource("GroupStyle") as Style;
    FieldSettings settings   = new FieldSettings();
    settings.CellClickAction = CellClickAction.SelectRecord;
    Field field              = new Field();
    field.Name               = "Value";
    field.Settings           = settings;
    field.Width              = new FieldLength(1, FieldLengthUnitType.Star);
    field.Label              = $"{product_name}\n[{unit}]";
    field.LabelTextAlignment = System.Windows.TextAlignment.Center;
    group.Children.Add(field);
    m_view.U_FieldLayout.FieldItems.Add(group);
    //this.m_view.CheckBox_Checked(null, null);
AddProductField is called under certain conditions to add a group, but the problem is that the checkbox defined as a style in HeaderPrefixArea is called.
The check event contains code that checks or unchecks all items in the data grid.
When inserting data into the data grid, the check box is checked and then entered into the data. However, after AddProductField is called, all data becomes unchecked.
