I have a XamDataGrid bound to hierarchical data of different data types. The FieldChooser shows a drop down list with each level, and then the columns associated with each data type as the drop down selection changes. Is there any way to make the FieldChooser display all the columns at once?
Thanks!
Hello Natalie,
The behavior you are getting is by design. We do not have any API exposed to set the FieldChooser for all the level's column at once, It would be a new feature idea for us which you can suggest for future version at https://ko.infragistics.com/community/ideas/i/ultimate-ui-for-wpf
Thanks, I assumed that was the case but figured I'd ask!
Natalie
