1385
DataGrid with dynamic combo box columns
I'm using WPF XamDataGrid 23.2.157 in a MVVM project.
I want to use a XamDataGrid bound to a DataTable. The DataTable elements are just strings. The tables are dynamic (not known at compile time), and columns can be added/removed.
I want to be able to add columns, and then for each row in each column users select from a set of values (coming from the view model) in a combo box. Every cell should be bound to the same list of options.
I also want to be able to delete columns, preferrably with a delete 'x' in the column header.
I have started by handling FieldLayoutInitialized, but I'm wondering if there is a simple way to do this without handling events?
