var field = new NumericField() { Width = FieldLength.Auto, Name = $"RefData{no}", Label = $"{item.Name} ({item.Unit})", DataType = typeof(double), AllowEdit = true, Format = Datas.RefFormat, EditorStyle = m_view.TryFindResource("Stype_NumericMaskedEditor") as Style, HorizontalContentAlignment = System.Windows.HorizontalAlignment.Right }; this.m_view.U_FieldLayout.Fields.Add(field);
<Style x:Key="Stype_NumericMaskedEditor" TargetType="{x:Type igEditors:XamNumericEditor}"> <Setter Property="Mask" Value="{}{double:4.10}" /> <Setter Property="InvalidValueBehavior" Value="RevertValue" /> <Setter Property="AcceptsArrowKeysInEditMode" Value="False" /> <Setter Property="ValueConstraint"> <Setter.Value> <igEditors:ValueConstraint MaxInclusive="9999.99" MinInclusive="0" Nullable="False" /> </Setter.Value> </Setter> </Style>
private string _RefData1 = "0"; public string RefData1 { get { return _RefData1; } set { _RefData1 = value; OnPropertyChanged("RefData1"); } }
If I set the initial value of RefData1 to "0", it will be displayed as the initial value when the unbound field is added. However, I want the field to remain blank until a value is entered.
RefData1
When I set RefData1 to an empty string (""), val becomes null in the SetDataValueHelper method. While this behavior is expected, how can I achieve my desired behavior?
val
null
SetDataValueHelper
