178
Data in columns go invisible when dragging columns with BoundFields and UnboundFields
When I try reordering columns in XamDataGrid and the FieldLayout got a mix of BoundField objects and UnboundField objects, the data
are no longer visible. If I debug, I see the Fields are not deleted, however, no data is any longer visible. If I reorder columns in a XamDataGrid
with only BoundField objects, this problem is not visible. I have used the example code I have found in these posts to support drag and dropping
columns in XamDataGrid.
  • 22852
    Assuming that you are using the Move method of the Field to rearrange the Fields, I am seeing the same behavior on my machine.  I have also tested this with the latest internal build and this didn't have the problematic behavior.  As such, I would recommend opening a case with Developer Support so that you may be notified when a hot fix is released that no longer has this issue.
    Cases can be opened with developer support with the following link:
    http://ko.infragistics.com/support/submitrequest.aspx
