45
Extending xamDataGrid Fields with additional properties
Is there a way to extend fields in a xamDataGrid with additional dependency properties that are synchronized between the field and the editor? I know that I can use TemplateField, but I'd rather create a derived field type for commonly used scenarios.
For example, we are using a TextBox with a button to clear the content. Our MyTextBox therefore has a dp 'IsClearable'. Now I want to create a column with this TextBoxes, using a derived field MyTextField and a corresponding MyTextEditor. The user should be able to use hardcoded values, FieldBinding and CellBinding.
For convenient usage I put the dependency property 'IsClearable' on the MyTextField so the user can set it in xaml defining the data grid columns. But how do I sync this property to the corresponding dp on MyTextEditor? As far as I see there is no connection between them both. I looked into default fields and they all sync their properties hardcoded and I found no way to extend this by custom properties.
  • 45
    Verified Answer
    After digging a little deeper, I found the methods InitializeEditorProperties and SynchronizeEditorProperty on type Field to override. Those methods should solve all the above mentioned problems.
