15
need to show Percents on XamPieChart(Infragistics 2014)
Hi
I need to show percents on XamPieChart(Infragistics 2014)
I checked infragistics 2014 sample browser
and XamPieChart - Labels With Percentage - Options - Labels Displayed - Percent function could show the percentage.
But couldn't find how to use it
Could you advise me how to ?
Thanks for ur support in advance
  • 2700
    Thank you for posting to Infragistics Community!
    Please, find attached below a sample app demonstrating how to display the item labels in the XamPieChart as percentage values.
    The approach involves defining a LabelTemplate for the chart:
     <ig:XamPieChart Name="pieChart"
    LabelTemplate="{StaticResource labelTemplate1}"/>
    As you can see, the text is bound to a property of the Label DataContext named “PercentValue” and additionally, a custom converter is used to adjust the percent value:
    <Grid.Resources>
         <local:ValueToPercentConverter x:Key="conv" />
         <DataTemplate x:Key="labelTemplate1">
             <StackPanel Orientation="Vertical">
                 <TextBlock Text="{Binding PercentValue, StringFormat=P, Converter={StaticResource conv}}" />
             </StackPanel>
         </DataTemplate>
     </Grid.Resources>
       public class ValueToPercentConverter : IValueConverter
          public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
              double dv = (double)value;
              if (dv > 0)
                  return dv / 100;
              return value;
          public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
              throw new NotImplementedException();
    In conclusion, please, check out the sample and let me know if it helps.
    Best regards,
    Bozhidara Pachilova
    Software Developer
    XamPieChartPercentages.zip
