I've got a class to hold a variable number of column values as shown below:
public class DataEntry{ // List of columns and their values private List<string> columns = new List<string>(); public List<string> Columns { get {return columns;} set {columns = value;} }}
And I've got a list of them in:
List<DataEntry> records = new List<DataEntry>();
How do I set XamDataGrid up such that when I do xdgGrid.DataSource = records, each column will be displayed as an individual column, instead of being nested?
XamDataGrid creates columns out of properties on the data source objects. It cannot create columns out of a list of strings. What you could do, however, is create a DataTable whose DataColumns are based on that list of strings, and then bind the XamDataGrid to the DataTable.
