Hi, my app loads various pages thru a NavigationService. In the main page there is a XamCarouselPanel w/ a standard Item Navigator. When I leave that page and later came back, the items are there but the Navigator disappears. Notice that it's property "visible" is still true, I never change it. Any Suggestion ?
The best way to get the work-around is to report the issue (which will show that more than one user is experiencing this defect, which will expedite it getting fixed) and request that a work-around be offered. Please contact developer support to report this issue. There is an online form you can fill out at the following webpage:
http://ko.infragistics.com/support/ask-for-help.aspx
Thank you!
I have the same problem, also with 8.2.
Is there any workaround available ?
This is a bug. If you would, please report the problem describing how you put together the layout. The URl for our online support page is:http://ko.infragistics.com/support/submitrequest.aspx
You can request a workaround to correct the problem when you report the problem.
