470
Tab Navigation with UnboundedFields
Hi I am using XamGrid and having problem in providing tab navigation on it cells.I am using a couple of UnboundFeilds in XamGrid and specifying CellValuePresenter for them.The Code looks sopmething like this
        <igDP:XamDataGrid>
            <igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:FieldLayoutSettings AutoGenerateFields="False">
                </igDP:FieldLayoutSettings>
            </igDP:XamDataGrid.FieldLayoutSettings>
            <igDP:XamDataGrid.FieldLayouts>
                <igDP:FieldLayout>
                    <igDP:FieldLayout.Fields>
                        <igDP:UnboundField Name="PaidAmount" Label="Amount">
                            <igDP:UnboundField.Settings>
                                <igDP:FieldSettings CellValuePresenterStyle="{StaticResource AmountCellStyle}" />
                            </igDP:UnboundField.Settings>
                        </igDP:UnboundField>
                    </igDP:FieldLayout.Fields>
                </igDP:FieldLayout>
            </igDP:XamDataGrid.FieldLayouts>
        </igDP:XamDataGrid>
and the CellValuePresenter is something like this
        <Style x:Key="AmountCellStyle" TargetType="{x:Type igDP:CellValuePresenter}">
            <Setter Property="Template">
                <Setter.Value>
                    <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                        <StackPanel Orientation="Horizontal" HorizontalAlignment="Right">
                            <igEditors:XamCurrencyEditor />
                        </StackPanel>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
        </Style>
The problem i am facing is that if i press tab to navigate to next cell/record only the cell gets the tab focus rather than the control inside that cell.So with above code if you hit tab then cell gets selected where as i need the focus on the CurrencyEditor(which is inside that cell)
Thanks in advance.
Rehman.
  • 6867
    If you would like to embed a XamCurrencyEditor into the cells of an UnboundField, I suggest you set the EditorType on the FieldSettings, instead of use a custom control template.   Here's how you can set that:
    <igDP:FieldSettings EditorType="{x:Type igEditors:XamCurrencyEditor}" />
    Josh
