339
Style and Dependency Property Question
I have a problem where I'd like to override the "BackgroundSelected" DP of the DataRecordCellArea class with my own implementation. e.g.
            <Style x:Key="rowStyle" TargetType="{x:Type igDP:DataRecordCellArea}">
                    <Setter Property="BackgroundSelected" Value="{Binding ElementName=ucMyDataGrid, Path=SelectedRowBackgroundColor}" />
            </Style>
This works fine when the property "SelectedRowBackgroundColor" has been set, but when it's value is still null I would like to use the original value of DP "BackgroundSelected", that the underlying Theme applied. Shouldn't this be possible with a dependency property?
I've also tried referencing the theme's style for DataRecordCellArea, but the style's "setters" collection doesn't let you reference a setter by property name, only index.
Any ideas appreciated,
Jamie
