250
"File selection" Field
 Hi everyone,
I would like to create in XamDataGrid a column with a XamTextEditor and a Button.
What I want is an editabile File selection column.
How can I implement this feature?
I do that bin this way:
        <Style TargetType="{x:Type igs:CellValuePresenter}" x:Key="myCustomFieldCell">
            <Setter Property="Template">
                <Setter.Value>
                    <ControlTemplate TargetType="{x:Type igs:CellValuePresenter}">
                        <Grid>
                            <Grid.ColumnDefinitions>
                                <ColumnDefinition Width="0.8*"></ColumnDefinition>
                                <ColumnDefinition Width="30"></ColumnDefinition>
                            </Grid.ColumnDefinitions>
                            <igE:XamTextEditor BorderThickness="0"
                                               VerticalAlignment="Center"
                                               Text="{TemplateBinding Content}">
                            </igE:XamTextEditor>
                            <Button Grid.Column="1" Content="..." Width="30"
                                    Command="{x:Static ui:Window2.OpenProgramCommand}"/>
                        </Grid>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
        </Style>
But I have several problem when I select the cell and with the edit mode. I can edit only after 2 click when I cahnge row selection. Can you help me? Thanks in advance.
  • 250
    Verified Answer
     I solved by this way:
        <Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="fileSelectionColumn">
                <Setter.Value>
                    <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                        <Grid ToolTip="{TemplateBinding Content}" Height="22">
                            <ContentPresenter Name="PART_EditorSite">
                                <ContentPresenter.Content>
                                    <igE:XamTextEditor VerticalContentAlignment="Center" VerticalAlignment="Center"
                                                       Text="{TemplateBinding Content}"/>
                                </ContentPresenter.Content>
                            </ContentPresenter>
                            <Button Grid.Column="1" Content="..." Width="30" Height="20" VerticalAlignment="Center"
                                    Command="{x:Static ui:WorklistPresentationModel.SelectProgramCommand}"/>
                        </Grid>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
        </Style>
