hi,
I have i graph 2D line in window, but it does not display on all windows .
i'd like to know if it's possible the resize the graph , and the scale ?
thanks
Nathalie
yes, it's possible to resize the graph... you either use the Axis.X.Extent / Axis.Y.Extent properties, or the Size property of the control.
based on the image you attached, i can't see the bounds of the control though. try setting the BackColor to something other than white, in order to determine how much space the UltraChart control is really using.
