My XamDataGrid has 3 fields(No, Action, ActionInfo). WhenInfo field has 5byte data. so, the data means time(HH:mm) or datetime(yy/MM/dd HH:mm) or custom data.
so, i am using datatrigger.
<Style x:Key="ActionInfoCellValueEditorStyle" TargetType="{x:Type igEditors:XamTextEditor}"> <Style.Triggers> <DataTrigger Binding="{Binding Path=Cells[Action].Value}" Value="255"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <StackPanel> <TextBlock Text="{Binding Converter={StaticResource nonDataConverter}, RelativeSource={RelativeSource TemplatedParent}, Path=Value, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" VerticalAlignment="Center" HorizontalAlignment="Center"/> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> <Setter Property="EditTemplate" > <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <StackPanel> <TextBlock Text="None"/> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> </DataTrigger> <DataTrigger Binding="{Binding Path=Cells[Action].Value}" Value="0"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <StackPanel> <TextBlock Text="{Binding Converter={StaticResource partitionConverter}, RelativeSource={RelativeSource TemplatedParent}, Path=Value, Mode=TwoWay}" VerticalAlignment="Center" HorizontalAlignment="Center"/> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> <Setter Property="EditTemplate"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <Grid> <ComboBox Grid.Column="0" ItemsSource="{Binding Source={StaticResource odpPartitionList}}" IsSynchronizedWithCurrentItem="True" DisplayMemberPath="Text" SelectedValuePath="Value" SelectedValue="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value.[0], Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"/> </Grid> </ControlTemplate> </Setter.Value> </Setter> </DataTrigger> <DataTrigger Binding="{Binding Path=Cells[Action].Value}" Value="1"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <StackPanel> <TextBlock Text="{Binding Converter={StaticResource partitionConverter}, RelativeSource={RelativeSource TemplatedParent}, Path=Value, Mode=TwoWay}" VerticalAlignment="Center" HorizontalAlignment="Center"/> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> <Setter Property="EditTemplate"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <Grid> <ComboBox Grid.Column="0" ItemsSource="{Binding Source={StaticResource odpPartitionList}}" DisplayMemberPath="Text" SelectedValuePath="Value" SelectedValue="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value.[0], Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"/> </Grid> </ControlTemplate> </Setter.Value> </Setter> </DataTrigger>
<igDP:XamDataGrid.FieldLayouts> <igDP:FieldLayout> <igDP:FieldLayout.Fields> <igDP:Field Name="No" Label="No" IsScrollTipField="True"> <igDP:Field.Settings> <igDP:FieldSettings AllowResize="False" LabelWidth="50" LabelMaxWidth="50" CellWidth="50" CellMaxWidth="50" AllowEdit="False"/> </igDP:Field.Settings> </igDP:Field>
<igDP:Field Name="Action" Label="Action"> <igDP:Field.Settings> <igDP:FieldSettings EditorStyle="{StaticResource scheduleActionComboBoxEditor}"/> </igDP:Field.Settings> </igDP:Field> <igDP:Field Name="ActionInfo" Label="Information" IsExpandable="False"> <igDP:Field.Settings> <igDP:FieldSettings EditorStyle="{StaticResource ActionInfoCellValueEditorStyle}" EditorType="{x:Type igEditors:XamTextEditor}"/> </igDP:Field.Settings> </igDP:Field> </igDP:FieldLayout.Fields>
however, my code has a problem. first time, when i edit Action field, ActionInfo is displayed by data trigger. but, when i edit Action field after i edit ActionInfo field, ActionInfo filed is displayed by old data. but, after XamDataGrid was redraw by grouping, ActionInfo field is displayed by new data.
How can i modify my code??
