I mean i need to bind unbound fields programmatically but i cannot manage to bind to a DataSource of type ObservableCollection<ObservableCollection<String>> sCol :
<igDP:XamDataGrid x:Name="xamDataGrid" DataSource="{Binding sCol}"> <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AutoGenerateFields="False" /> </igDP:XamDataGrid.FieldLayoutSettings> <igDP:XamDataGrid.FieldLayouts> <igDP:FieldLayout> <igDP:FieldLayout.Fields> <igDP:UnboundField Label="Col1" BindingPath="[0]" BindingMode="TwoWay" DataType="sys:String" /> <igDP:UnboundField Label="Col2" BindingPath="[1]" BindingMode="TwoWay" DataType="sys:String"/> </igDP:FieldLayout.Fields> </igDP:FieldLayout> </igDP:XamDataGrid.FieldLayouts> </igDP:XamDataGrid>
Ouput traces say :
System.Windows.Data Error: 39 : BindingExpression path error: '[' property not found on 'object' ''EnumerableObjectWrapper' (HashCode=14407208)'. BindingExpression:Path=[1]; DataItem='EnumerableObjectWrapper' (HashCode=14407208); target element is 'a' (HashCode=44344604); target property is 'Value' (type 'Object')
I can achive a correct binding through a regular listView though :
<ListView ItemsSource="{Binding sCol}"> <ListView.View> <GridView> <GridViewColumn Header="Col1" DisplayMemberBinding="{Binding [0]}"/> <GridViewColumn Header="Col2" DisplayMemberBinding="{Binding [1]}"/> </GridView> </ListView.View> </ListView>
It seems that the grid DataSource property does not behave like the list ItemsSource property.
What am I missing ?
Cheers.
Shakti,
You would need an IEnumerable exposed by a data item. See the following example:
XamDataGrid xamDataGrid1 = new XamDataGrid(); xamDataGrid1.PreviewMouseDoubleClick += new MouseButtonEventHandler(xamDataGrid1_PreviewMouseDoubleClick); this.Content = xamDataGrid1; xamDataGrid1.FieldLayoutSettings.AutoGenerateFields = false; ObservableCollection<string> headers = new ObservableCollection<string> { "FirstName", "LastName", "Age" }; ObservableCollection<string> childHeaders = new ObservableCollection<string> { "ChildField1", "ChildField2", "ChildField3" }; ObservableCollection<string> childRow1 = new ObservableCollection<string> { "One", "Two", "Three" }; ObservableCollection<string> childRow2 = new ObservableCollection<string> { "One", "Two", "Three" }; ObservableCollection<string> childRow3 = new ObservableCollection<string> { "One", "Two", "Three" }; ObservableCollection<ObservableCollection<string>> childTableValues = new ObservableCollection<ObservableCollection<string>> { childRow1, childRow2, childRow3 }; ObservableCollection<string> row1 = new ObservableCollection<string> { "John", "Doe", "19" }; ObservableCollection<string> row2 = new ObservableCollection<string> { "Jane", "Doe", "21" }; ObservableCollection<string> row3 = new ObservableCollection<string> { "Suzie", "Q", "52" }; ObservableCollection<string> row4 = new ObservableCollection<string> { "No", "Body", "48" }; ObservableCollection<DataRow> tableValues = new ObservableCollection<DataRow>(); tableValues.Add(new DataRow() {Values=row1, Children = childTableValues}); tableValues.Add(new DataRow() { Values = row2 }); tableValues.Add(new DataRow() { Values = row3 }); tableValues.Add(new DataRow() { Values = row4 }); FieldLayout fldLayout = new FieldLayout(); Field f = new Field(); f.Name = "Children"; fldLayout.Fields.Add(f); for (int i = 0; i < headers.Count; i++) { string s = headers[i]; UnboundField uf = new UnboundField(); uf.Name = s; uf.Label = s; uf.BindingPath = new PropertyPath("Values[" + i.ToString() + "]", null); fldLayout.Fields.Add(uf); } FieldLayout childLayout = new FieldLayout(); for (int i = 0; i < childHeaders.Count; i++) { string s = childHeaders[i]; UnboundField uf = new UnboundField(); uf.Name = s; uf.Label = s; uf.BindingPath = new PropertyPath("[" + i.ToString() + "]", null); childLayout.Fields.Add(uf); } xamDataGrid1.FieldLayouts.Add(fldLayout); xamDataGrid1.FieldLayouts.Add(childLayout); xamDataGrid1.DataSource = tableValues;
The above will require the following additional class:
public class DataRow { private ObservableCollection<string> values = new ObservableCollection<string>(); public ObservableCollection<string> Values { get { return this.values; } set { this.values = value; } } private ObservableCollection<ObservableCollection<string>> children = new ObservableCollection<ObservableCollection<string>>(); public ObservableCollection<ObservableCollection<string>> Children { get { return this.children; } set { this.children = value; } } }
I would still recommend using a DataTable over this approach and if you are seeing performance issues when using the DataTable I would like to see a sample demonstrating the issue so that I can look into how to improve the performance.
Let me know if you have any questions with this matter.
Hi Alan,
Please suggest how can I use ObservableCollection<ObservableCollection<string>> for tableValues for Hierarchical Data ? How can I specify relationship between 2 levels?
Shakti
For resolving the performance issue, I would recommend starting with going through the suggestions in Optimizing Infragistics XamDataGrid Performance.
If you have been through that and are still seeing performance issues then it would be best to get a sample from you demonstrating the issue so we can see what is causing the decrease in performance.
I have Hierarchical xamDataGrid, with 4 levels, each level with 2000+ rows. I need to keep updating whole Grid (all rows) in every 3 sec. Since I need to support Dynamic Columns, I am using DataSet with 4 DataTables, and DataRelation for Hierarchical Data. I finish updating DataSet in 1 sec. But When I try to update UI (xamDataGrid) using the INotifyPropertyChanged RaisePropertyChangedEvent('xamDataGrid') from ViewModel, it freezes screen for 5-20 seconds or more. If all 4 levels are collapsed, it works fine, but if all 4 levels are expanded then it freezes for 20 seconds or more.
Thanks,Shakti
Please provide more details on what you are looking for. If you are looking for a dynamic data structure, it would be simpler to use a DataSet than to use the code that I provided above. The code that I have provided above was meant as an example of how you could use unbound Fields to show items from a collection. Note that the simplified example has many limitations including that there are no change notifications for when changes are made to the data.
