I am having an issue with the combo box events.
When I place a combobox in a Ribbon group I cannot get it to fire any of the changed events.
Anyone else having this issue?
Here is the XAML to test this with
<Window
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
x:Class="Window1"
Title="Window1" Height="480" Width="640" xmlns:igRibbon="http://infragistics.com/Ribbon">
<Grid>
<igRibbon:XamRibbon x:Name="testRibbon">
<igRibbon:XamRibbon.Tabs>
<igRibbon:RibbonTabItem Header="Test">
<igRibbon:RibbonGroup Id="grpTest" Caption="Test Group">
<igRibbon:ComboEditorTool Id="cboTest" Caption="combo test" SelectedItemChanged="ComboEditorTool_SelectedItemChanged" ValueChanged="ComboEditorTool_ValueChanged">
</igRibbon:ComboEditorTool>
<igRibbon:ComboEditorTool x:Name="cboTesting" Id="cboTest1" Caption="combo test">
<igRibbon:TextEditorTool x:Name="txtTesting" Id="txtTest" Caption="Test Textbox" TextChanged="TextEditorTool_TextChanged" >
</igRibbon:TextEditorTool>
</igRibbon:RibbonGroup>
</igRibbon:RibbonTabItem>
</igRibbon:XamRibbon.Tabs>
</igRibbon:XamRibbon>
</Window>
And here is the code behind
Imports Infragistics.Windows.Ribbon
Private Sub ComboEditorTool_SelectedItemChanged(ByVal sender As System.Object, ByVal e As System.Windows.RoutedPropertyChangedEventArgs(Of System.Object))
End Sub
MessageBox.Show("Value Changed Fired.", "It works", MessageBoxButton.OK, MessageBoxImage.Exclamation)
'Add some stuff to the combobox
If Not cbo Is Nothing Then
cbo.ComboBox.Items.Add("Testing " & i.ToString)
Next
End If
MessageBox.Show("TextEditorTool Text Changed Fired.", "It works", MessageBoxButton.OK, MessageBoxImage.Exclamation)
'Private Sub TextEditorTool_KeyDown(ByVal sender As System.Object, ByVal e As System.Windows.Input.KeyEventArgs)
' MessageBox.Show("TextEditorTool KeyDown Fired.", "It works", MessageBoxButton.OK, MessageBoxImage.Exclamation)
'End Sub
'Private Sub TextEditorTool_KeyUp(ByVal sender As System.Object, ByVal e As System.Windows.Input.KeyEventArgs)
' MessageBox.Show("TextEditorTool KeyUp Fired.", "It works", MessageBoxButton.OK, MessageBoxImage.Exclamation)
MessageBox.Show("cboTesting Selected Item Changed Fired.", "It works", MessageBoxButton.OK, MessageBoxImage.Exclamation)
End Class
Thanks, I had already submitted this one but I was hoping for a work around like the one that you provided. Seems like this is a quicker way to get a workaround than waiting for support to issue one. Priortiy what is that?
This looks like a bug. You should report the issue to the support group so you can be notified when a fix is available. When you contact them reference issue #8836. In the interim, you can get around the problem by setting the ItemsProvider property to a new ComboBoxItemsProvider and adding items to that instead. The events are raised in this case.
