25
Field name must be unique. How to deal with object composition?
The list binded here is à list of Contacts objects. A contact is composed of an object ContactName which is composed of 2 strings “First” and “Last”.
My problem is the field name must be unique. So, how can I do to display ContactName.Last and ContactName.First in two differents columns.
This doesn’t work too:  <igDP:Field Name="ContactName.First" Label="Last Name">
Here is my xaml code:
<Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="StyleTemplatePersonNameFirst">
    <Setter Property="Template">
        <Setter.Value>
            <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                <Grid>
                    <TextBlock Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content.First}"/>
                                </Grid >
            </ControlTemplate>
        </Setter.Value>
    </Setter>
</Style>
<Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="StyleTemplatePersonNameLast">
        <Setter.Value>
                <Grid  >
                    <TextBlock Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content.Last}"/>
                                </Grid >
            </ControlTemplate>
        </Setter.Value>
    </Setter>
</Style>
<TabItem Name="TabItemAllXamDataGrid"  Header="_All (XamDataGrid)" >
    <igDP:XamDataGrid Name="xamDataGridAll" BindToSampleData="False"  DataSource="{Binding}" GotFocus="xamDataGridAll_GotFocus" >
        <igDP:XamDataGrid.FieldLayoutSettings>
            <igDP:FieldLayoutSettings AutoGenerateFields="False"  />
        </igDP:XamDataGrid.FieldLayoutSettings>
        <igDP:XamDataGrid.FieldLayouts>
            <igDP:FieldLayout>
                <igDP:Field Name="ContactName" Label="Last Name">
                    <igDP:Field.Settings>
                        <igDP:FieldSettings CellValuePresenterStyle="{StaticResource StyleTemplatePersonNameLast}" />
                    </igDP:Field.Settings>
                </igDP:Field>
!!! This doen’t work because field name must be unique !!!
                <igDP:Field Name=" ContactName " Label="First Name">
                        <igDP:FieldSettings CellValuePresenterStyle="{StaticResource StyleTemplatePersonNameFirst}" />
                </igDP:Field>
                </igDP:FieldLayout.Fields>
            </igDP:FieldLayout>
        </igDP:XamDataGrid.FieldLayouts>
    </igDP:XamDataGrid>
