Is there sample code to demonstrate how to use DataPresenter for tree representation like the folders screen in your samples showcase.
I tried looking thru online documentation but I could n't find anything on this.
ANy help is appreciated. Thanks!
In versions 2009.1 there are new samples in the ShowCase. I believe the one you are referring (xamTravagtanca) is last included in 2008.1. However, there is nothing special in the sampe.A XamDataPresenter is used with a hierarchical data source. The GroupByAreaLocation is set to None, LabelLocation to Hidden.
I could not find the file xamTravaganza.xaml in the NetAdvantage for .NET 2009.1 version! Is there a version difference or something else?
This sample is included in the xamShowcase solution that ships with the product. You can find the xamShowcase folder by opening the QuickStart (Start > Infragistics > NetAdvantage for WPF > Get Going > Quick Start). From there, select "Open the xamShowcase Project Folder". Once you have the solution opened, you can find the tree sample in the file xamTravaganza.xaml.
I would suggest going to http://ko.infragistics.com/gethelp and click 'Request developer Support Online'.
