Hy all.
I am using a XamRibbon in which I have some groups and buttons (I have set the KeyTip for the buttons in the ribbon). In some groups I use Separators to group the buttons. Something like this:
<igRibbon:RibbonGroup Name="rgrStaticDataParameter" Caption="Merkmale" >
<igRibbon:MenuTool Caption="Merkmale" ToolTip="Merkmale/Verlaufswerte" ButtonType="Segmented" Name="Parameter" KeyTip="E">
<igRibbon:ButtonTool Caption="Merkmale" Name="btnNote" KeyTip="M"/>
<igRibbon:ButtonTool Caption="Merkmalwerte" Name="btnNoteValue" KeyTip="W"/>
<Separator/>
<igRibbon:ButtonTool Caption="Verlaufswerte" Name="btnCourseValue" KeyTip="V"/>
<igRibbon:ButtonTool Caption="Parameter" Name ="btnParameter" KeyTip="P"/>
<igRibbon:ButtonTool Caption="Erweiterte Parameter" Name ="btnParameterExtended" KeyTip="E"/>
</igRibbon:MenuTool>
</igRibbon:RibbonGroup>
The problem is when I press the ALT key to see the KeyTips. For all my buttons the KeyTips are correct, but I have KeyTips also for the Separator. Is this correct? I would like to remove this KeyTips for the Separator but I don't know how. Is there a way?
Thanks a lot for any suggestions.
Nico
Hy Andrew.
I used <igRibbon:SeparatorTool/> instead of <Separator/> and now it's working.
Thanks very much for the suggestion.
That sounds like a bug that you may want to submit to the support group but you can use an igRibbon:SeparatorTool instead and then you should not get a keytip.
