I m using the datatable.defaultview as a source for series and that series is added to the xamchart..............when i map the table on to the chart using the series.datamapping = "column" only the column values are plotted on the y-axis......thats alright how do i bring the corressponding labels column to the x-axis so that i have one column i.e. 'int' on the y axis........and the other column 'varchar(20)' on the x axis as labels......i.e. for each int there is a corressponding varchar on x axis???..........
this XAMCHART is gettin on my nerves!
Sorry for any confusion. These controls have so much depth that we are constantly adding to the documentation. Good catch.
Thanks!
Thanx man......but that Label part wasnt mentioned in the documentation............ur solution works.........I mean there it is mentioned to do "X = myXColumn; Y = myYColumn" .......which doesnt really work........
You can specify which object in your DataTable should be mapped to the Label in the DataMapping as well.
For example:
DataMapping="Value=SegmentA;Label=SeriesLabel";
