1240
Setting the Label Presenter’s Context Menu Property
An earlier post on the old forum suggested that a context menu could be assigned to a field/column header by setting the style on the Label Presenter.  I tried this via the following code.  The code in question is in red.
// Create and assign a field layout
FieldLayout theFieldLayout = new FieldLayout();
FieldLayouts.Add(theFieldLayout);
// Go through all column details
foreach (ColDetails CurrColDetails in m_ColHeaders)
    // Create the new field (Column)
    Field currColField = new Field();
    // Assign the label presenter
    currColField.Label = CurrColDetails.HeaderName;
    // Bind
    currColField.Name = CurrColDetails.Binding;
    // Add the new menu item
    MenuItem CurrColMenuItem = new MenuItem();
    CurrColMenuItem.Header = CurrColDetails.HeaderName;
    CurrColMenuItem.DataContext = CurrColDetails;
    CurrColMenuItem.Click += new RoutedEventHandler(MenuItemClickHandler);
    m_ContextMenu.Items.Add(CurrColMenuItem);
    // Add the new field to the field layout
    theFieldLayout.Fields.Add(currColField);
Style labelPresenterStyle = new Style(typeof(LabelPresenter));
labelPresenterStyle.Setters.Add(new Setter(LabelPresenter.ContextMenuProperty, m_ContextMenu));
foreach (Field currField in theFieldLayout.Fields)
    currField.Settings.LabelPresenterStyle = labelPresenterStyle;
grid.FieldLayouts.Add(theFieldLayout);
This results in an exception being thrown after the grid is initialized, the  source of which I have not been able to determine.  I do know that if I take out the style logic (shown in red) the exception does not get thrown.
Am I using the ContextMenuProperty correctly?  I cannot find any documentation anywhere that describes its use.  Thank you.
