170
Cannot bind using a DataTemplate in the XamDataPresenter
I would like to know how to bind an object to a field in the XamDataPresenter using a DataTemplate.  It seems to be using the DataTemplate correctly, but I do not know how to retrieve the data I need, which in the example below is the “FillColor” property.
<igDP:XamDataPresenter.Resources>
  <Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="Status">
    <Setter Property="ContentTemplate" Value="{StaticResource LightboardStatusTemplate}" />
  </Style>
</igDP:XamDataPresenter.Resources>
<igDP:XamDataPresenter.FieldLayouts>
  <igDP:FieldLayout>
    <igDP:FieldLayout.Fields>
     <igDP:Field Name="STATUS" Label="Lightboard">
      <igDP:Field.Settings>
        <igDP:FieldSettings CellWidth="70" LabelWidth="70" AllowEdit="False" CellValuePresenterStyle="{StaticResource Status}">
        </igDP:FieldSettings>
       </igDP:Field.Settings>
      </igDP:Field></igDP:FieldLayout.Fields>
   </igDP:FieldLayout>
</igDP:XamDataPresenter.FieldLayouts>
<ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
                    xmlns:DRAMSClient="clr-namespace:Rades">
    <DataTemplate x:Key="LightboardStatusTemplate" DataType="{x:Type DRAMSClient:LightboardStatus}">
        <Label Content="{Binding Path=FillColor}" />
    </DataTemplate>
</ResourceDictionary>
    public class LightboardStatus
        private string _FillColor;
        public string FillColor {
            get
                return "#" + _FillColor;
            set
                _FillColor = value;
        public string BorderColor { get; set; }
  • 170
    Verified Answer
    Nevermind.  This was my fault.  I realized that when I added a column to a DataRow, I did not set the column type to typeof(LightboardStatus).  This made it so that when the LightboardStatus object was set as the value of a cell of the new column, it was converted to its string representation.
