Hy all.
I use a XamDockManager for which I have set the PaneNavigatorButtonDisplayMode="Always".
When the PaneNavigator it's displayed it has two regions for "Active Files" and "Active Tool Windows". Is it possible to change this texts so that the texts are dispalyed in anothers languages?
Thanks.
Nico
Thanks Andrew, it's working.
The help file lists the strings available for localization as well as instructions on how to localize them using the ResourceCustomizer.
http://help.infragistics.com/Help/NetAdvantage/WPF/2008.2/CLR3.X/html/WPF_Assembly_Resource_Strings.html
http://help.infragistics.com/Help/NetAdvantage/WPF/2008.2/CLR3.X/html/WPF_Customize_Assembly_Resource_Strings.html
http://help.infragistics.com/Help/NetAdvantage/WPF/2008.2/CLR3.X/html/WPF_DockManager_Resource_Strings.html
The two strings in question are associated with the resources named 'PaneNavigatorActiveFilesLabel' and 'PaneNavigatorActiveToolWindowsLabel'.
