Hello
I'm using theme Generic but are modifying the colors a little bit. My problem is with foreground when I hover a row. At first when I hover or select a row the foreground in each cell changes to the new color, but if I hover over diffrent cells in the row the foreground color change back to the default color in the cell I leave.
As you guessed I don't want that, I want the foreground in the cells to stay in the hover/selected style until I leave the row and not to change while I hover over diffrent cells in the same row.
If anyone can help me with a solution to this I would be very happy.
/Sara
Hello Sara,
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Thank you for your post. I have been looking through it and I attached a sample project that shows how foreground colors are changing depending on different events. You can also see this article:
http://blogs.infragistics.com/blogs/andrew_smith/archive/2009/12/09/common-style-issues-when-using-the-theme-property.aspx
which will help you understand better styling and themes in WPF.
If you need any further assistance on this matter do not hesitate to ask.
