When I add a date time editor control to a ribbon, it doesn't allow me to change the month when I click on the left and right arrows of the popup calender control. The control just collapses to its default text editor view.
The IsAlwaysInEditMode setting was just a way to avoid the editor from changing its template (which would take the monthcalendar out of the visual tree) when it left edit mode. You should report the issue to the support group.
Hi Andrew,
I've got the same problem.
<igEditors:XamDateTimeEditor IsAlwaysInEditMode="True" DisplayMode="IncludeBoth" /> does not help.
Is there any solution for the collapsing Calendar in Ribbon?
Thank you.
This seems like a bug and should be reported to the support group. When you report the issue, please reference issue #11631. The problem is actually with the editor or maybe a combined interaction. For now, you can get around that aspect by setting its IsAlwaysInEditMode to true although you may notice that keyboard focus is not within the dropdown anymore.
e.g.
