Hello Guys,
I have been reading through your issue and am not quite sure what is the matter in your scenarios. I can suggest you look through these forum threads to see if they help:
http://forums.infragistics.com/forums/p/45354/246119.aspx#246119 ,
http://forums.infragistics.com/forums/p/47295/252973.aspx# ,
http://forums.infragistics.com/forums/p/47324/253015.aspx#253015 ,
http://forums.infragistics.com/forums/p/15705/252972.aspx#252972
If not please describe in more details your cases and if possible illustrate with a few screenshots just to make sure we are on the same side.
Looking forwards to hearing from you.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
I am also experiencing this issue, and have not been able to produce a solution for it.
