140
Cell Activating Event Problem
In my Record Updating event i set the IsActive property to true for PaymentMethodCodeDescription field in the XamDataGrid as shown in bold/italic below.
if (e.Record.Cells["PaymentMethodCodeDescription"].Value == null)
{                       MessageBox.Show("Payment Method Code Description cannot be empty");                e.Record.Cells["PaymentMethodCodeDescription"].IsActive = true;
                e.Record.Cells["PaymentMethodCodeDescription"].IsSelected = true;
                StartEditMode();                e.Action = RecordUpdatingAction.CancelUpdateRetainChanges;               // e.Handled = true;                _isValid = false;
                return;
 However, though the IsActive property for PaymentMethodCodeDescription cell is set to true, CellActivating event is fired sometimes and sometimes not.  Please could anyone help me with this? Thanks in advance.
  • 7694
    When you are using the RecordUpdating event, you are activating the cell before that (cell is already activated), therefore in some cases CellActivating will not be called again. I believe this could be expected in some cases.
    What is the scenario that you are trying to achieve? Maybe moving the code in other events will be a better idea? Or canceling the event in RowUpdating, then setting the cell to edit mode again?
    Thanks.
