Been trying to load and save customizations but it appears as though field visibility is not saved in the XML string. I am giving my users the option to change column visibility and it would have been nice to be able to save this customized info.
Am I missing something?
"<?xml version=\"1.0\" encoding=\"utf-8\"?>\r\n<xamDataPresenter version=\"8.2.20082.1002\">\r\n <fieldLayouts>\r\n <fieldLayout key=\"SitMessage\">\r\n <fields>\r\n <field name=\"SourceName\" />\r\n <field name=\"SourceId\" />\r\n <field name=\"DestinationId\" />\r\n <field name=\"DestName\" />\r\n <field name=\"RouteLink\" />\r\n <field name=\"Retries\" />\r\n <field name=\"Type\" />\r\n <field name=\"Id\" />\r\n <field name=\"MessageNumber\" />\r\n <field name=\"Status\" />\r\n <field name=\"ReceiveTime\" />\r\n <field name=\"TransmitTime\" />\r\n <field name=\"QueuedTime\" />\r\n <field name=\"FailureTime\" />\r\n <field name=\"Title\" />\r\n <field name=\"Direction\" />\r\n <field name=\"Message\" />\r\n <field name=\"Key\" />\r\n <field name=\"Directory\" />\r\n <field name=\"Filename\" />\r\n <field name=\"TimeStamp\" />\r\n </fields>\r\n </fieldLayout>\r\n <fieldLayout key=\"Object\" />\r\n </fieldLayouts>\r\n</xamDataPresenter>"
Alex,
This above link appears to have expired. Do you know if there is an example like it available elsewhere? I too have a tab control and need to bounce back and forth on tabs without losing previous settings.
Glenn
Here is an article about the SaveCustomization method of the xamDataGrid.
http://help.infragistics.com/Help/NetAdvantage/WPF/2008.2/CLR3.X/html/xamData_Save_Field_Customizations.html
Saving of the Visibility property is not supported. You can manually try to save this property with custom code.
