755
Field Layout in report
In my application, I have a large grid that shoes many columns.  There is to many columns to fit on one paper page event in landscape.  I can make it fit by changing the column setup.  Putting 3 rows in 1 record (FieldMoving) so the data is "wraped" to fit on the page.  The result on paper is fine, but I dont want to use the same fieldLayout on paper and on screen.  Is it possible to change it only for reporting and not on screen?
Karine.
  • 4850
    Hi Karine,
    Yes, you can wire up the events on the cloned datapresenter used inside the print by listening for the PaginationStaring event of the EmbedddVisualReportSection, e.g.:
    EmbeddedVisualReportSection evrs = new EmbeddedVisualReportSection(this.xamGrid);
    evrs.PaginationStarting += new EventHandler<EmbeddedVisualPaginationEventArgs>(evrs_PaginationStarting);
    void evrs_PaginationStarting(object sender, EmbeddedVisualPaginationEventArgs e)
    DataPresenterBase reportDataPresenter = e.VisualPaginator as DataPresenterBase;
    if ( reportDataPresenter != null )reportDataPresenter.FieldLayoutInitialized += new EventHandler<FieldLayoutInitializedEventArgs>(clonedGrid_FieldLayoutInitialized);
    void clonedGrid_FieldLayoutInitialized(object sender, FieldLayoutInitializedEventArgs e)
    FieldLayout fl = e.FieldLayout;
    // do stuff
    Joe
