175
specify axis min and max without specifying unit
Hello Infragistics,
It would be very helpful to be able to manually set the min and max for a chart axis without having to also specify a unit size.  The chart obviously decides on a unit size when the min and max are calculated automatically, so it seems like it would be fairly easy to have the chart do the same thing but with manually set min and max.
Not having this feature degrades the value of the XamChart component significantly as a good unit/tick size calculation algorithim is one of the most useful (and basic) features of COTS charting components.
Zac Morris
CTO
Missing Link Systems, Inc.
  • 739
    Hi Zac,
    Thank you for you suggestions. Right now if auto range is used minimum, maximum and unit values have to be set. This is done because of compatibility with all Infragistics chart components which have same behaviour. We will definitely put this as a feature request for the next version.
    Reagrds,
    GoranS
