200
Application Menu Height
i've try to set MinHeight ot Height property of the application menu of a Ribbon.
When i execute the window, the menù are displayed in center of screen ... there are other method to set the height or is a problem of the ribbon?
Thank's
  • 54937
    The ApplicationMenu element is the orb you see in the upper left portion of the ribbon so I don't think you want to set its MinHeight. It sounds like you would want to retemplate it to change the MinHeight of the Popup it contains but I would recommend reviewing the Office UI Guidelines as doing so may violate your license agreement with MS that allows you to use the ribbon. I believe the guidelines stipulate that the height of the ribbon must be no larger than the size needed for the tools.
