755
Define an hierarchical datagrid manually
Relate with this post: http://forums.infragistics.com/forums/t/20265.aspx
I want to create an hierarchical datagrid but instead be automatic I want to create it manually.
For example, I have a ObervableCollection<Person> , but for each person I want to convert Person.Id to a DataTable with the current loans via WPF converter derived class and show that DataTable nested to the Person row.
Wich will be the correct way to do it?
I'm using:
                    <igDp:FieldLayout.Fields>
                        <igDp:Field Name="Name" Row="0" Column="0"/>
                        <igDp:Field Name="Surname" Row="0" Column="1"/>
                        <igDp:Field Name="Title" Row="0" Column="2"/>
                        <igDp:Field Name="Id" Converter="{StaticResource loanConverter}" Row="1" Column="0" ColumnSpan="3" IsExpandable="True" />
                    </igDp:FieldLayout.Fields>
                </igDp:FieldLayout>
 Where loanConverter returns a DataTable, but the bottom row appears empty.
Cheers.
