229
xamCarouselListBox databinding using Item Template
I am trying to create an item template to bind to a datatabel and use it in the xamCarouselListBox in code C#.
I would like to create a stackpanel with the items I want on it that bind to a datatable. Something like
 AggregationDataView is a DataView
DataTemplate tmpData = new DataTemplate{ DataType = typeof(string) };
StackPanel sp = new StackPanel { Orientation = System.Windows.Controls.Orientation.Vertical };foreach (DataColumn col in AggregationDataView.Table.Columns)
TextBlock tbItem = new TextBlock { ToolTip = col.ColumnName };
tbItem.SetBinding(TextBlock.TextProperty, col.ColumnName);
sp.Children.Add(tbItem);
tmpData.Resources.Add(sp,
null);
xamCarouselListBox1.ItemTemplate = tmpData;
xamCarouselListBox1.ItemsSource = AggregationDataView.Table.DefaultView;
Doesnt seem to work can you help?
thanks
Mark
  • 69686
    Hello Mark,
    You can check the samples in the XamFeatureBrowser about the XamCarouselListBox. There is a great example of custom DataTemplate. You can also see the default styles of the controls that we ship in the local directory ~\Infragistics\NetAdvantage for WPF 2008 Vol. 2\DefaultStyles on your computer and build you styles and templates on this base.
    Hope this helps.
