35
Search in XamDataGrid
Hi all,
is it possible to add a search field in the XamDataGrid? For example a field above every column in the XamDataGrid, where the user can enter a search string and the items will be filtered.
  • 115
    Hope this helps for you.
    Keep TextBox for Searching a string on Key Up event of Textbox just do this logic it will effect.
    for (int count = 0; count < Grid.Records.Count; count++)
    DataRecord dr = Grid.Records[count] as DataRecord;
    String cellvalue=dr.Cells[ColumnIndex].Value.toString();
    if(cellvalue.ToUpper().StartsWith(textbox1.Text.ToUpper()))
    Grid.Records[count].Visibility = Visibility.Visible;
    else
    Grid.Records[count].Visibility = Visibility.Collapsed;
  • 8576
    Hi -
    Please submit a support request for this at http://ko.infragistics.com/gethelp for suggestions on how to achieve this scenario.
    Joe Modica
