540
xamChart live data display sometimes show warning message?
Hello :
        I adopt xamchart to display live data. I found that sometimes xamchart will show warning message as below:
         index over the range. It is necessary to be positive and smaller than the size. Parameter name:index
      I test my demo program that the warning message will happen almost when the program produces 200 datapoints and the warning message will happen frequently as soon as first warning message appears.
      I put a xamDataGrid to show the live data at the same time  to check whether it is program problem or infragistics control problem.
I found XamDataGrid is ok but XamChart is problem.
  Is this a XamChart bug?
 The XAML code is as below:
<Window
 xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
 xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
 x:Class="ChartBugTest.Window1"
 x:Name="Window"
 Title="Window1"
 Width="640" Height="480" xmlns:igCA="http://infragistics.com/Chart" xmlns:igDP="http://infragistics.com/DataPresenter">
 <Grid x:Name="LayoutRoot">
  <igCA:XamChart Margin="136,8,192,198" x:Name="TempMeter1Chart">
  <igCA:XamChart.Caption>
        <igCA:Caption Text="Temperature"/>
       </igCA:XamChart.Caption>
  </igCA:XamChart>
  <igDP:XamDataGrid  AutoFit="True" Margin="136,0,192,22" VerticalAlignment="Bottom" Height="160" x:Name="DataDisplay" DataSource="{Binding Path=CurrentValue, Mode=TwoWay}" />
 </Grid>
</Window>
The code behind is as below
using System;
using System.Data;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Shapes;
using System.ComponentModel;
using System.Timers;
using System.Windows.Threading;
using Infragistics.Windows.Chart;
namespace ChartBugTest
 /// <summary>
 /// Window1.xaml 的互動邏輯
 /// </summary>
 public partial class Window1 : Window
        BoundObject bo = new BoundObject();
        private Random _random = new Random();
        private DispatcherTimer _timer = new DispatcherTimer();
        private DataSet ds = new DataSet();
        private DataTable dt = new DataTable("datatable");
        private DataSet cds1 = new DataSet();
        private DataTable cdt1 = new DataTable("datatable");
        private Series s1 = new Series();
        private string t = "";
        private int ct1 = 0;
  public Window1()
   this.InitializeComponent();
   // 在此點下方插入建立物件所需的程式碼。
            StartGauge();
        public void StartGauge() //必須判斷是否已經執行過
            if (!_timer.IsEnabled)
                _timer.Interval = new TimeSpan(0, 0, 0, 0, 1500);
                _timer.Tick += new EventHandler(_timer_Elapsed);
                Loaded += new RoutedEventHandler(IAmLoaded);
                bo = new BoundObject { CurrentValue = 11, CurrentValue1 = 5, CurrentValue4 = 10332 };
                DataContext = bo;
                _timer.Start();
                InitialTable();
                InitialChart();
                InitialChartData();
        /// <summary>
        /// On load show value
        /// </summary>
        /// <param name="sender"></param>
        /// <param name="e"></param>
        void IAmLoaded(object sender, RoutedEventArgs e)
            SetValues();
        void _timer_Elapsed(object sender, EventArgs e)
            try
                SetValues();
                BindToChart();
                BindToGrid();
            catch (Exception err)
                MessageBox.Show(err.Message + "..and.. the currentvalue is:" + bo.CurrentValue);
        /// <summary>
        /// Set the value and display
        /// </summary>
        private void SetValues()
            int thevalue = _random.Next(40);
            int thewetvalue = _random.Next(10);
            if (thevalue >= 10)
                bo.CurrentValue = thevalue;
                do
                while (thewetvalue < 3);
                bo.CurrentValue1 = thevalue - thewetvalue;
                bo.CurrentValue2 = thevalue + 1;
                bo.CurrentValue3 = bo.CurrentValue2 - 3;
            int airpressure = _random.Next(10340);
            if (airpressure>=100)
                bo.CurrentValue4 = airpressure;
            t = DateTime.Now.ToString("hh:mm:ss:tt");
        private void InitialTable()
            dt.Columns.Add("count", typeof(Int32));
            dt.Columns.Add("time", typeof(string));
            dt.Columns.Add("temperature", typeof(Int32));
            ds.Tables.Add(dt);
            DataDisplay.DataSource = ds.Tables["datatable"].DefaultView;
        private void InitialChart()
           TempMeter1Chart.Caption.Text = "Temperature Chart";
           TempMeter1Chart.Visibility = Visibility.Hidden;
        private void InitialChartData()
            //---Chart1 -------------------------------
            cdt1.Columns.Add("count", typeof(Int32));
            cdt1.Columns.Add("temperature", typeof(Int32));
            cds1.Tables.Add(cdt1);
            s1.DataSource = cds1.Tables["datatable"];
            s1.DataMapping = "temperature";
            s1.ChartType = ChartType.Spline;
            TempMeter1Chart.Axes.Clear();
            Axis primAxisX1 = new Axis();
            primAxisX1.AxisType = AxisType.PrimaryX;
            primAxisX1.AutoRange = true;
            TempMeter1Chart.Axes.Add(primAxisX1);
            Axis primAxisY1 = new Axis();
            primAxisY1.AxisType = AxisType.PrimaryY;
            primAxisY1.AutoRange = true;
            primAxisY1.Unit = 3;
            TempMeter1Chart.Axes.Add(primAxisY1);
            if (!TempMeter1Chart.Series.Contains(s1))
                TempMeter1Chart.Series.Add(s1);
            //----- end of Chart1 -------------------
        private void BindToGrid()
            DataRow dr = dt.NewRow();
            dr["count"] = ct1;
            dr["time"] = t;
            dr["temperature"] = bo.CurrentValue;
            dt.Rows.Add(dr);
            ds.AcceptChanges();
            DataDisplay.DataItems.Insert(0,dr);
        private void BindToChart()
            //--- Chart1 -----------------
            DataRow dr1 = cdt1.NewRow();
            dr1["count"] = ct1++;
            dr1["temperature"] = bo.CurrentValue;
            cdt1.Rows.Add(dr1);
            TempMeter1Chart.RefreshEnabled = true;
            if (ct1 > 1)
                TempMeter1Chart.Visibility = Visibility.Visible;
            //---- end of chart1 --------------------------------
    #region data bound class
    /// <summary>
    /// Class to do an example binding
    /// </summary>
    public class BoundObject : INotifyPropertyChanged
        private double _currentValue;
        private double _currentValue1;
        private double _currentValue2;
        private double _currentValue3;
        private double _currentValue4;
        /// <summary>
        /// Current vlaue property, raises the on property changed event
        /// </summary>
        public double CurrentValue
            get { return _currentValue; }
            set
                _currentValue = value;
                OnPropertyChanged("CurrentValue");
        /// <summary>
        /// </summary>
        public double CurrentValue1
            get { return _currentValue1; }
            set
                _currentValue1 = value;
                OnPropertyChanged("CurrentValue1");
        /// <summary>
        /// </summary>
        public double CurrentValue2
            get { return _currentValue2; }
            set
                _currentValue2 = value;
                OnPropertyChanged("CurrentValue2");
        /// <summary>
        /// </summary>
        public double CurrentValue3
            get { return _currentValue3; }
            set
                _currentValue3 = value;
                OnPropertyChanged("CurrentValue3");
        /// <summary>
        /// </summary>
        public double CurrentValue4
            get { return _currentValue4; }
            set
                _currentValue4 = value;
                OnPropertyChanged("CurrentValue4");
        #region INotifyPropertyChanged Members
        /// <summary>
        /// One of my properties has changed
        /// </summary>
        public event PropertyChangedEventHandler PropertyChanged;
        /// <summary>
        /// Notify any listeners that a property has changed
        /// </summary>
        /// <param name="propName">Name of the property</param>
        protected virtual void OnPropertyChanged(string propName)
            if (PropertyChanged != null)
                PropertyChanged(this, new PropertyChangedEventArgs(propName));
        #endregion
    #endregion
  • 540
    posted in reply to David Negley
    Hello:
    I already update to new hotfix version 8.2.20082.2001 and it seems ok in the sample I posted but I found that the problem is still happen as soon as I put the xamChart in an usercontrol and display the usercontrol in the window. If I put xamChart in the usercontrol the trouble happened almost on 266 datapoints. Actually my ongoing project adopts 6 xamcharts in one usercontrol and that trouble condition happened on almost 100 datapoints.
    I guess it was because the xamChart continuously to get the max value of primaryX to repaint itself but as the live data entering and whole dataset is large therefore xamChart could not get the necessary max value when it deceide to repain itself. Following is a simple sample of xamChart in usercontrol and trouble happens on almost 266 datapoints.
    ------------- window1 xaml code-------------------
    <Window
     xmlns="
     x:Name="Window"
     Title="Window1"
     Width="640" Height="480" xmlns:igCA="http://infragistics.com/Chart" xmlns:igDP="http://infragistics.com/DataPresenter" xmlns:ChartBugTest="clr-namespace:ChartBugTest">
      <ChartBugTest:UCChart Margin="10,10,10,10" x:Name="Chart1"/>
     </Grid>
    </Window>
    ------------------end--------------------------
    -----window1 code behind ------------------
    using System.Linq;
    using System.Text;
     /// <summary>
     /// </summary>
      public Window1()
    ----------------end ---------------------------
    --- UCChart.xaml usercontrol xaml code------------
    <UserControl
     xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
     xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
     mc:Ignorable="d"
     x:Class="ChartBugTest.UCChart"
     x:Name="UserControl"
     d:DesignWidth="640" d:DesignHeight="480" xmlns:igCA="http://infragistics.com/Chart" xmlns:igDP="http://infragistics.com/DataPresenter">
      </igCA:XamChart>
     </Grid>
    </UserControl>
    -------------------end---------------------
    ---UCChart.xaml code behind ----------------------
    using System;
    using System.Data;
    using System.Text;
    using System.Windows.Navigation;
     /// <summary>
     /// UCChart.xaml 的互動邏輯
     /// </summary>
     public partial class UCChart
      public UCChart()
                StartGauge();
                    DataContext = bo;
                    _timer.Start();
                    InitialTable();
                    InitialChart();
                    InitialChartData();
            /// <summary>
            /// </summary>
                SetValues();
                try
                    SetValues();
                    BindToChart();
                    BindToGrid();
            /// <summary>
            /// </summary>
                if (thevalue >= 10)
                    do
                if (airpressure >= 100)
                ds.Tables.Add(dt);
                dr["count"] = ct1;
                dr["time"] = t;
                dt.Rows.Add(dr);
                ds.AcceptChanges();
                DataDisplay.DataItems.Insert(0, dr);
                cdt1.Rows.Add(dr1);
                if (ct1 > 1)
        /// <summary>
        /// </summary>
            /// <summary>
            /// </summary>
                set
            /// <summary>
            /// </summary>
                set
            /// <summary>
            /// </summary>
                set
            /// <summary>
            /// </summary>
                set
            /// <summary>
            /// </summary>
                set
            /// <summary>
            /// </summary>
            /// <summary>
            /// </summary>
            #endregion
        #endregion
    ---------------------end ----------------------------
    Hope this sample is helpful for bug resolved.
    Sincerely,
                        Daniel Lee 2009/3/5
  • 28496
    i was able to get the sample running using your source code, but after waiting for 250 points to appear, i didn't see any error messages using both the release build (7.2.20072.1000) and the latest source code for 7.2.
    what is the complete (4-part) version number of the Infragistics dlls you're using?
