I have hierarchical data. There is a one to one relationship between my parent and child. My requirements dictate that only the child be displayed in the grid. What is the best way to accomplish this with xamDataGrid?
My first approach was to create a new DataRecordPresenter style that has a new Template and set that on the grid. However I get a null exception during runtime and the only information from that exception is a stacktrace that goes deep into Infragistics code. Also, I am not sure what to put in the Template.
You should be able to specify it the same way, e.g. if your property returns an ArrayList it would be:
If it is a custom class of yours you would have to map the local namespace that contains the class. Note: if you are deriving from a generic class like ObservableCollection<T> I don't think there is any way of specifying that in xaml. In this case, you would either have to set the DataType of the UnboundField in code by wiring up the FieldLayoutInitialized event of derive a class from ObservableCollection<T> so you could specify it in xaml.
Tanks for your anser. I was just making a suggestion. Would'nt it be a good idea to enable the possibility to use 1 for 1 object relationship like regular fields?
By the way, I did'nt figured out the way to specify the DataType when its a Collection.
Tanks.
Using an Unbound field you would need to specify the DataType to pick up the default formatting and the approriate editor, e.g.:
<Window ... xmlns:sys="clr-namespace:System;assembly=mscorlib" > ...
DataType="{x:Type sys:Decimal}"
Here is 2 examples of xamdatagrid using the same object. In the first example, its a collection using the object only, in the second example, its a collection of an other object that has a 1 for 1 relationship with the same object from the first example. Both examples are supposed to display the exact same data. In the first example, I have data in the Master and Detail part of the grid, in the second example, I dont have data in the Detail part becose I have to find a way to specify the DataType. In the first example, the double values are shown justified on the right and rounded to 2 decimales, in the second example, the double values are shown justified on the right and not rounded.
Here is the first example, using Fields
http://img145.imageshack.us/my.php?image=fieldlayoutsetupla1.png
<igDP:Field Label="classe d'actif" Name="LongDescription"/>
<igDP:Field Label="Percentage" Name="Percentage"/>
<igDP:Field Label="BookValueInvestmentCost" Name="BookValueInvestmentCost"/>
<igDP:Field Label="AccruedInterestDividend" Name="AccruedInterestDividend"/>
<igDP:Field Label="AnnualIncome" Name="AnnualIncome"/>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
Here is the second example, using UnboundField.
http://img296.imageshack.us/my.php?image=unboundfieldssc5.png
<igDP:FieldLayout.Fields>
<igDP:Field Label="classe d'actif" Name="Name"/>
<igDP:UnboundField Label="BookValueInvestmentCost" BindingPath="AssetMixClassRaw.BookValueInvestmentCost"/>
<igDP:UnboundField Label="AccruedInterestDividend" BindingPath="AssetMixClassRaw.AccruedInterestDividend"/>
<igDP:UnboundField Label="AnnualIncome" BindingPath="AssetMixClassRaw.AnnualIncome"/>
<igDP:UnboundField Label="Sous niveau Classes"
BindingPath="AssetMixClassRaw.AssetClasses"
<igDP:UnboundField Label="Sous niveau Positions"
BindingPath="AssetMixClassRaw.Positions"
Hmmm, I'm sure sure what is going on here. Any chance of posting a small sample that demonstrates it here so I can take a look?
