180
Formatting Columns for Currency, Date, etc.
I have looked around but I can't find a solution that either works or specifically answers my question.  I have a simple datagrid setup to display data from a List<T>.  One of the columns is a currency value stored as a Decimal and one is a DateTime object.
The date looks ok but I want to drop the time from the end of it.  The decimal is just a decimal.  I want it to show comma's for every 3 digits and I only want two decimal places (it currently shows about 8 I think).
I have tried a number of approaches including setting the Coverter however while the coverter code is being called and is converting values (I checked) the column is empty whenever I use this.
It seems to me this should be a lot simpler, a simple StringFormat parameter perhaps?  What am I missing here that is making this so difficult?
Here is the xaml:
<igDP:XamDataGrid x:Name="RepTakeDataGrid" DataSource="{Binding RepTakeDataSource}" Theme="Office2k7Blue" VirtualizingStackPanel.IsVirtualizing="True" VirtualizingStackPanel.VirtualizationMode="Recycling">
                    <igDP:XamDataGrid.FieldLayoutSettings>
                        <igDP:FieldLayoutSettings AutoGenerateFields="False" HighlightAlternateRecords="True"
                                                  AllowAddNew="False" AllowDelete="False" />
                    </igDP:XamDataGrid.FieldLayoutSettings>
                    <igDP:XamDataGrid.FieldLayouts>
                        <igDP:FieldLayout >
                            <igDP:FieldLayout.FieldSettings>
                                <igDP:FieldSettings AllowSummaries="True" CellClickAction="SelectRecord" ExpandableFieldRecordHeaderDisplayMode="DisplayHeaderOnlyWhenExpanded" />
                            </igDP:FieldLayout.FieldSettings>
                            <igDP:FieldLayout.Fields>
                                <igDP:Field Name="Amount" Label="Take Amount ($)"   Converter="{StaticResource formatConvertor}" ConverterParameter="'{0:C2}'"  />
                                <igDP:Field Name="EntryAccount" Label="Entry Account"/>
                                <igDP:Field Name="SplitAccount" Label="Split Account" />
                                <igDP:Field Name="RepNumber" Label="Rep #" />
                                <igDP:Field Name="RepName" Label="Rep Name" />
                                <igDP:Field Name="DateReceived" Label="Date" />
                                <igDP:Field Name="RepCodeString" Label="Rep Code" />
                                <igDP:Field Name="ClientName" Label="Client" />
                                <igDP:Field Name="PolicyNumber" Label="Policy #" />
                                <igDP:Field Name="EntryType" Label="Type" />
                            </igDP:FieldLayout.Fields>
                        </igDP:FieldLayout>
                    </igDP:XamDataGrid.FieldLayouts>
                </igDP:XamDataGrid>
Also if you notice anything else wrong with this approach please let me know.
Chris
