Hi
I am new to the XamDataGrid(using the trial version) and i would like to know how to use a datepicker control(or a XamDateTimeEditor maybe..) within a cell when it is being edited.
Thanks in advance
Thanks andrew , i'll check that out
You would have to use the non-Express versions - i.e. the Full version - so you would need to download the Win Client install.
Yes Andrew you are right.Then i'll have to use different assembly versions i guess.
So, could you tell which versions to use.
Abhilash
I'm guessing that you are using the Express versions of the assemblies. The Express versions do not include the masked editors like XamMaskedEditor, XamDateTimeEditor, etc. - only the XamTextEditor and XamCheckEditor.
Hello ABhilash,
I have attached a sample with a sample project with different types of editors. There is one field with a XamDateTimeEditor.
Hope this helps you.
Alex.
