Is there an event that fires in the Infragistics XamCarouselPanel every time the items in the panel are moved/rotated? Specifically, I have a horizontal pathed XamCarouselPanel filled with System.Windows.Controls.Image objects. I am stuck trying to find a way to get an event fired from the current 'middle' image from the XamCarouselPanel whenever the XamCarouselPanel objects are moved/rotated.
Is this feature implementable using the XamCarouselPanel? I've been through the API Documentation, but I cannot seem to find any documented events that would trigger when i desire.
Well, according to this document, I think I should be using the xamlCarouselListBox to 'support single selection of items' instead of the base xamCarouselPanel.
I am not using the infragistics xamDataCarousel, I am using the xamCarouselPanel. That event hander logic doesn't do anything if I register it with my xamCarouselPanel.
I sitll might be able to use this as a starting point. I'll reply with my solution if I can create one.
Moving of the Records in the Carousel are linked to DataPresenterCommands. You can handle the ExecutedCommand event and check if the command is next or previous record like this:
void xamDataCarousel_ExecutedCommand(object sender, Infragistics.Windows.Controls.Events.ExecutedCommandEventArgs e)
if (e.Command == DataPresenterCommands.RecordNext)
Hope this helps,
Alex.
