I have a DataGrid where the property AllowFieldMoving is set to Yes. But I have some icons that should always be displayed on the left. They should never be mouved. But the rest of the columns can. The Property AllowFieldMoving should be off on this field only.
Is there a way to do this in xaml or do I need to listen to an event and manage it in the code behind?
Karine.
This sounds like you should use fixed fields to fix it to the left and you should cancel the the FieldPositionChanging event for that Field as Alex suggested.
