1155
Filter and Refresh two grids
Background & Expectations: My window has 2 independent grids with two independent data sources. They do have a common field, but this is not Northwind so there is no linking and no internal relationship.
When I double-click on a record in the top grid, I want too filter the view in the bottom grid such that I identify a key value in both and limit as such. Sounds easy until I realized XamDataGrid has no filtering.
Data: As far as my data goes it is very complex for the Infragistic brain. I am using nested lists which are further derived using linq query. I have massaged the data to the most basic level so that the poor datagrid can find it. The ResultsView is assigned to the DataContext and DataSource respectively.
The fun part:
I've got those two grids, one with an anonymous data type which I need to evaluate and convert to some data type. That's all set. I am attempting to use vew.Filter to filter out the bottom records by the current record in the top. Easy enough, but as usual I am having trouble telling XamDataGrid to refresh itself and use the new filter.
Question: How do I use view.refresh or assign the filtered view to the XamDataGrid and then actually make the view display it?
Suggestions Welcome.
I have included the filter portion of my code behind below.
Glenn
// Grid double-click event
private void RegoUnitsList_MouseDoubleClick(object sender, System.Windows.Input.MouseButtonEventArgs
e)
this
.SynchronizeActiveRecordWithCurrentItem();
// Filter Call
void
_Schedulesgrid =
this
.RegoSchedulesList;
_Unitsgrid =
this
.RegoUnitsList;
var view = this
.GetCurrentSchedulesView();
if (view == null
return
var unitsview = this
.GetCurrentUnitsView();
if (unitsview == null
return
// Get current Unit Record
var
currentUnit = unitsview.CurrentItem;
if (currentUnit == null
_Unitsgrid.ActiveRecord =
null
else
var currentUnitRec = _Unitsgrid.GetRecordFromDataItem(currentUnit, false
if (currentUnitRec != null
currentUnitRec.IsActive =
true
currentUnitRec.IsSelected =
true
_Unitsgrid.BringRecordIntoView(currentUnitRec);
count = 0;
// end if
view.Filter =
delegate(object
item)
List<ASEngine.BusinessObjects.Entities.ASRegoSeqment> MySegments = new List<ASEngine.BusinessObjects.Entities.ASRegoSeqment
var stronglyTyped = GlennsTypeHack.Cast(item, new { Schedules = default(Nullable<decimal>), UnitScheduleID = default(decimal), Unitschedulelongname = default(string), MinDown = default(string), MaxRun = default(string), MinRun = default(string
), Segments = MySegments });
if (stronglyTyped.Schedules.ToString() == currentUnitRec.Cells["UnitID"].Value.ToString() && stronglyTyped != null
return true
else
return false
view.Refresh();
// ????????????? This does not work
_Schedulesgrid.DataSource = view;
ICollectionView
return _Schedulesgrid.DataSource == null ? null : CollectionViewSource
.GetDefaultView(_Schedulesgrid.DataSource);
ICollectionView
return _Unitsgrid.DataSource == null ? null : CollectionViewSource
.GetDefaultView(_Unitsgrid.DataSource);
