70
XamChart Issues In Expression Blend
Good People,
I am experiencing serious problems getting my XamCharts to work.  When I try to use Expression Blend to create series and data point then perform bindings, it generates an error message stating that: the enumerator is not valid because the collection has changed.  Then, if I persist, expression blend crashes.  Overall, I am finding it very difficult to work with the xamChart control in expression blend, and even in visual studio in the xaml editor.  It makes expression blend very unstable.  Furthermore, it's as if any attempt to set bindings on the charts renders them inoperable.
Essentially, my strategy is to set the XamChart's datacontext and then bind the datapoints in a series, or map a series to the relevant property.  Unfortunately, while this has worked for one chart, it won't work for others.
Any help would be greatly appreciated.  We are nearing a production deadline and the charts are the only outstanding tasks.
I am using Expressoin Blend 2008 sp1, Visual Studio 2008 and .Net 3.5 sp1.  I am using the Net Advantage for WPF 2009 volume 1.
Thanks in advance and I look forward to hearing from you.
