I have a bit of a strange case,
I have a tab control.
And on each tab I have a grid.
Switching between these tabs is very slow.
You also end up with this in output window of visual studio every time you switch tabs:
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='DataPresenterBrushKeys.GroupByAreaBackgroundHighlightKey'; ResourceKey.HashCode='36205315'; ResourceKey.Type='Infragistics.Windows.Themes.StaticPropertyResourceKey'
If you turn off the office2007 theme these mesages go away and it speeds right up.
Odd? Quite.
It took me some work to reproduce my problem in a test app but this is what I have found.
If you add XamGrids to the tab control directly, no problems (switching stays fast). If the grids get added through a Wpf data biding the this problem occurs.
Something like this for example : (Where 'View' ends up being a control with a xamlGrid on it.)
<Window.Resources>
<DataTemplate x:Key="ContentTemplate">
<ContentControl Content="{Binding Path=View}"/>
</DataTemplate>
</Window.Resources>
<TabControl Name="BoundTabControl"
ContentTemplate="{StaticResource ContentTemplate}">
</TabControl>
Any ideas? or should I be sending this one to support.
Has this issue been solved? I'm facing the same with the latest Intragistics build...
Please let me know if this issue has been resolved and how. I was not able to follow a link in this forum that is supposed to have the answer
The issue is already addressed.
Please take a look at this post:
http://community.infragistics.com/forums/p/24535/93570.aspx#93570
Alex.
I also seem to have this problem. I have tabs with DataTempalte being bound to the control which contains your grid. The output window also has "Infragistics.Windows.Themes.StaticPropertyResourceKey" no found errors :(
Thanks!
