Ok so I know how to assign a data template to the legend's items. In XAML it's as easy as putting the data template for LegendItemTemplate in xamChart.Resources and setting Legend.UseDataTemplate = true.
But how do I do this in code behind? I've tried the following:
xamChart.Resources.Add(typeof(LegendItemTemplate), this.TryFindResource(typeof(LegendItemTemplate)));
xamChart.Resources.Add("itemTemplate", this.TryFindResource("itemTemplate"));
The resource is added to xamChart.Resources no worries but XamChart doesn't seem to be picking it up at all. If no theme is specified, the chart just shows the object name and if a theme is specified, it just shows the theme's default data template.
In silverlight your only options are either to declare the DataTemplate somewhere in the xaml resources and then you can access it from xaml like this:
{StaticResource keyName}
where keyName is the key you gave the DataTemplate.
Or you can access it from the code behind like this
(DataTemplate)Resources["keyName"]
Or, if you don't want to put it in the xaml somewhere, you will have to put the xaml as a string in a code file and use XamlReader to load it.
Hope this helps!
-Graham
Dears,
the FrameworkElementFactory is not supported in the silverlight 4 and 5, so what shall i do in order to load the datatemplate of the legenditemtemplate.
note: my datatemplate contains a checkbox
<DataTemplate> <Border BorderThickness="0.5" Margin="2" CornerRadius="5" Visibility="{Binding Series.Visibility}" Background="#99E6DEF5" BorderBrush="#FF794141"> <StackPanel Orientation="Horizontal" Margin="5" Width="140"> <CheckBox x:Name="chbPriceSeriesVisibility" Click="OnPriceSeriesVisibilityClick" IsChecked="True" VerticalAlignment="Center" HorizontalAlignment="Left"> </CheckBox> <ContentPresenter Content="{Binding}" Margin="5,0,5,0" ContentTemplate="{Binding Series.LegendItemBadgeTemplate}"/> <ContentPresenter Content="{Binding Series.Title, TargetNullValue=Series Title}" Margin="0,0,5,0"/> </StackPanel> </Border> </DataTemplate>
Good grief. I never would have figured that one out.
Thanks a lot!
i couldn't figure this out either until I found the answer here: http://stackoverflow.com/questions/491195/what-key-to-use-if-adding-a-data-template-to-the-resources-of-a-control
you learn something new every day. here's the code i used to create and apply the LegendItemTemplate.
// create datatemplate, set datatype DataTemplate legendItemTemplate = new DataTemplate(); legendItemTemplate.DataType = typeof(LegendItemTemplate); // root element in datatemplate is border. create and set properties on the border FrameworkElementFactory borderFactory = new FrameworkElementFactory(typeof(Border)); borderFactory.SetValue(Border.BackgroundProperty, new SolidColorBrush(Colors.Red)); // border contains a child TextBlock. create and set properties, then add it as a child of the border FrameworkElementFactory textBlockFactory = new FrameworkElementFactory(typeof(TextBlock)); textBlockFactory.SetBinding(TextBlock.TextProperty, new Binding("Text")); borderFactory.AppendChild(textBlockFactory); // set the border as the visual tree of the DataTemplate legendItemTemplate.VisualTree = borderFactory; // add it to the chart's resources collection this.xamChart1.Resources.Add(new DataTemplateKey(typeof(LegendItemTemplate)), legendItemTemplate); this.xamChart1.Refresh();
