I'm trying to get the carousel upon load to scroll the item (record index: 0) to be the centere'd item.
Upon click of an item, we use the ScrollInfo.SetVerticalOffset(recID - 3) - 3 is the magic number off to the left and right when we are using a ItemPerPage = 7.
ex: x x x X x x x upon load...should be like this: - - - X x x x (- is an empty space)
for whatever reason, when I click on one, it works to scroll it to the center, but when I click the far left one (aka the first item in the carousel), it will scroll to the center, however I have to send over -3 for that to happen. But when I try to do this upon load, it doesn't do that, it scrolls it to 0.
I have scroll item to center position = true set. Removing this however doesn't fix the problem.
