135
Problems for StackedColumn XamChart which seriese num exceeds 91
My Env: Visual Studio 2008  SP1  with .NetFramework3.5SP1
And Infragistics3.Wpf.Chart.v8.1
OS: Win 2003 EE SP2
 Problem: the tooltip is not shown correctly.  Please check.
Note that only the first statck on the left is correctly shown the tooltip and the later  tooltips are the same one
which showing the  last series' datapoint's tooltip.
XAML:
<Window x:Class="WpfApplication12.Window1"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
     xmlns:igChart="http://infragistics.com/Chart"
    Title="Window1" Height="600" Width="600">
    <Grid>
        <igChart:XamChart Name="chart">
            <igChart:XamChart.Series>
                <igChart:Series ChartType="StackedColumn"></igChart:Series>
            </igChart:XamChart.Series>
        </igChart:XamChart>
    </Grid>
</Window>
Code behind:
public partial class Window1 : Window
        public Window1()
            InitializeComponent();
            loadData();
        private void loadData()
            TestData[] td = new TestData[91];
            for (int i = 0; i < td.Length; i++)
                List<TestInnerData> list = new List<TestInnerData>();
                for (int j = 10; j >= 0; j--)
                    list.Add(new TestInnerData() { Date = DateTime.Now.AddDays(-j), Amount = 100000 });
                td[i] = new TestData() { Host = "myhost-w2k3s-" + i, DataForHost = list };
            chart.Series.Clear();
                string branchServerName = td[i].Host;
                Series mySeries = new Series()
                    ChartType = ChartType.StackedColumn,
                    Label = branchServerName
                foreach (TestInnerData data in td[i].DataForHost)
                    DataPoint dp = new DataPoint()
                        Label =data.Date.ToString("MMM dd"),
                        Value = data.Amount,
                        ToolTip = null
                    dp.ToolTip = string.Format(branchServerName + ":{0}", dp.Value);
                    mySeries.DataPoints.Add(dp);
                chart.Series.Add(mySeries);
        public class TestData
            public String Host
                get;
                set;
            public List<TestInnerData> DataForHost
                get;
                set;
        public class TestInnerData
            public DateTime Date
                get;
                set;
            public double Amount
                get;
                set;
  • 28496
    Suggested Answer
    it looks like "fast rendering mode" has been enabled and the labels are repeating due to an optimization gone awry.  you can use this code to work around the problem:
                <igChart:XamChart.Scene>
                    <igChart:Scene>
                        <igChart:Scene.GridArea>
                            <igChart:GridArea>
                                <igChart:GridArea.RenderingOptions>
                                    <igChart:GridAreaRenderingOptions RenderingMode="Full" />
                                </igChart:GridArea.RenderingOptions>
                            </igChart:GridArea>
                        </igChart:Scene.GridArea>
                    </igChart:Scene>
                </igChart:XamChart.Scene>
            </igChart:XamChart>
