1650
Unbound checkbox field initially appears as null value (7.2 RTM)
Hi there
I have a grid on a dialog with an unbound checkbox on it. During the InitializeRecord event, the checkbox' value is set to false (btw: a DefautValue property would be nice).
However - the grid always looks as if the value would be null - even if I set the initial value to true. The values are correctly set - reading Record.Cell[x].Value returns the correct boolean value. I assume it's a styling issue, because if I toggle the checkbox values through code to true, it looks like a checkbox with a null value AND a check mark. Subsequent toggling is correct:
