Hi ,
i need to export my report in PDF ,there is any feature in Infragistic.Reporting that allow me to save my report in PDF?
If not,how i can work out this feature with Infragistic Component?
Thanks for your time.
Thanks Andrew for your reply,
I iwll look your documents and find out a solution to allow me to print in PDF.
Have a good work.
No, currently the reporting will only print and output to xps. You would have to use a print driver that creates a pdf file, convert the xps to pdf or you would need to instead use something like our Documents assembly and manually create the pdf file.
