I didn't see any examples of using a data set from a database for the X/Y of a series. I have a dataset that will have 2 columns, ErrorDate and ErrorCount. I want the ErrorDate data to be the X axis data points, and the ErrorCount to be the Y axis values. Do you have any examples of how to do this? I will also be adding additional chart series' to the same chart, which will all have the same column format. All the examples I've seen seem to use a pivoted data set, which won't work for me.
Thanks.
Dan
Thanks! That did the trick!
This is from the handler for event Window.Loaded. It works for me.
Series series1 = new Series(); series1.ChartType = ChartType.ScatterLine; series1.DataSource = this.theTable; series1.DataMapping = "ValueX = timeStamp; ValueY = val1"; series1.Label = "val1"; this.xamChart1.Series.Add(series1); Series series2 = new Series(); series2.ChartType = ChartType.ScatterLine; series2.DataSource = this.theTable; series2.DataMapping = "ValueX = timeStamp; ValueY = val2"; series2.Label = "val2"; this.xamChart1.Series.Add(series2);
Bill
