I have try to do some drag and drop but it interferre with the multi-selection. So, it will be fine the have a sample that allow to drag records from the grid to another control.
1 - When I implement drag and drop, I loose multi-selection because it try to drop on the same control
2 - When I add a "check" to see if it is on the same control, I completely loose the drag !!
So, I do not know how I can do !!!
http://ko.infragistics.com/gethelp (scroll down to 'Request Developer Support Online')
Joe Modica
